Ric
- May 7, 2010
- 5,765
Try TSC Tractor Supply for your mojack there $99 there
MoJack® EZ Lawn Mower Lift - Tractor Supply Online Store
Something I saw in another thread in a post by user Ric pointed out that grass blades themselves are made up of/consist of 70%-80% water. Maybe that in and of itself negates any possibility of a viable solution of complete prevention of grass clipping buildup underneath a mower deck.
There's nothing your going to spray on a deck to keep grass from sticking. People keep trying everything under the sun but never find the answer. We may not like it but it's the nature of the beast.
Cakey is absolutely correct about the best solution being a thorough cleaning immediately after wet mowing. This is a very practical approach for some mowers that have easy access to the bottom of the mower deck. For many midmount ZTR's, however, this can be quite difficult, especially for those having trouble physically getting underneath.
This is why I REALLY wish that my Grasshopper had the power deck. I have a floor jack that raises the deck relatively easily, but my mid mount Bad Boy is only accessible by lying on my side with a piece of metal strap as a scraping tool.
The undercoating might work good, but I would think that the surface would have to be Spic & Span clean in order for it to stick.
Larry
Why not make a "deck shower" out of lawn sprinklers? Just mount it to a board, hook up your water hose and drive over it a couple of times an use a mirror to see if its clean enough :wink: I,m sure that would clean it after a few times using it after your done for the day:drink:
