I'llusetbehammerjustonce
- Jun 27, 2026
- 1
Have a Zt1 with 300 hrs, so it's been great! Suddenly can't get the blades to turn, changed PTO switch, the drive belt turns when I use the switch (even if I'm not sitting on it which is strange) the belt is on correctly, 1/2 inch deflection so I assume tight enough - I'm not really very technical so I've heard people online suggest Ohm checks but I'm not sure how to do that - could the seat safety switch cause it to not engage - again the mower will run and turn the drive belt with me not sat on it. Any easy checks - I don't see any wires hanging etc turning the PTO I hear a slight- - sqeal but it does turn - any help much appreciated
