I think my old wizard is Mtd so Im posting here. Any Ideas?? It has a 8hp Briggs electric start and a 30" deck.
It is RARE that I see anything that says Wizard... but I'm sure there are a few still around, I was looking to see some others pop up in your post... I've got an old Wizard tiller, the one with a VERY heavy cast iron body... has not been used since the 60's.is this a rare tractor?
I made my rippers out of 2x4 tubing.:thumbsup: Here's a pic of the finished boxblade.
I guess back then they needed to mow quick:biggrin:
BB is 60"wide and 24" high. use my GC2400 Massey to pull it.:biggrin:I may try to duplicate that ripper unless I use something solid. what is the height of the blade, and what model tractor pulls that?
Well I went for a ride and this thing hauls @$$. It must go 12 in 3rd. I don't think the pulley has been changed. 1st and 2nd aren't that fast but third. I guess back then they needed to mow quick:biggrin:
Thank you for those specs. Also nice tractor. I may scale that by half 30" by 1'. I have never used a box blade. I would like some opinions on how big of a box blade to make for the sears suburban, I do have 55 lb. wheel weights. But how wide is too wide??:confused3:
Well the mower deck she runs good. Just needs some grease but haven't gotten there yet. It took me a few minutes to figure out how to engage the blades, but I finally got it. All it takes is lowering the deck and it puts tension on the belt. I guess I'm just used to a blade clutch lever.
