Where can I find an owner's manual
Neisman
Where can I find an owner's manual for my Troy Bilt Bronco tractor.
Model 37746 Ser. 1C274H10287.
I checked w/ Troy Bilt site and the MTD site.
Both show no information for that model/ser.#.
KennyV
WELCOME to LMF...
Are you Sure about that model # ??
Neisman
WELCOME to LMF...
G'day,
I am absolutely positive that is the model and serial numbers under the seat.
Because I purchased it used, I am NOT certain that it is the original seat.
Is there someplace else where I can look for the model/serial numbers?
Thanks, Karl
Neisman
You don't know if what would be similar to mine? The seat? It looks like an exact replacement if not original.
Neisman
Re: Where can I find an owner's manual and a grill
Don't know if that will be similar to yours... :smile:KennyV[/QUOTE]
Hopefully these pictures will help someone identify my tractor. I need a grill for it.
xp14629
Have you called the troy-bilt 800 number on the serial number recall. That number is for parts and customer service. If the parts guys can't get anything with the numbers you read off to them, ask for the customer service and they should be able to get you the correct numbers. Everything on that sticker looks to be correct and intact. The seat is also the correct one, unless someone found one off a used model in which case only the serial number shoulder be different. The new seat would not come with the sticker on it.
KennyV
The 62 page owners manual that is linked there...
It is for a "Super" Bronco... there may be some similarities, If your manual is no longer available... :smile:KennyV
flyerdan
Didn't see that exact model listed, but if you don't mind spending a bit of time looking for something that looks right there are a bunch listed on Manuals Online.
Neisman
Thanks everybody. I think with that info, I can get something.
This is my first tractor. My neighbor mowed my grass for 20 years. I bought his property and with the spring will come mowing for me again.
