Have you called the troy-bilt 800 number on the serial number recall. That number is for parts and customer service. If the parts guys can't get anything with the numbers you read off to them, ask for the customer service and they should be able to get you the correct numbers. Everything on that sticker looks to be correct and intact. The seat is also the correct one, unless someone found one off a used model in which case only the serial number shoulder be different. The new seat would not come with the sticker on it.
