twall
- Feb 27, 2011
- 78
- 1,628
Let's keep this to lawn and garden-type machines, single or two cylinder, two or four stroke.
My favorite is 4 stroke B&S, and here's why:
B&S, IMHO, are the longest-running, simplest, cheapest to fix, most abuseable engine on the market. Bar none.
I have never had luck with tecumseh. Constant carb problems, electrical problems, and the rings don't seem to last as long as they do on other brands. When the rings go, the oil thins out, and you end up siezing up, or throwing a rod. Just my personal exp. with them. You might have had better luck. I've owned 5 of them, and the best one is in my white snowblower. But, that one is starting to have carb problems, too!
The Japanese marques, like Honda and Kawasaki are strong, quiet, and reliable. For a time. But their carbs go to pot real quick. When you do have problems, rebuilding them is hard to do, hard to find the kits for, and very expensive. I've had 2 single cyl air-cooled Kawi's (both on JD's), and a Honda 5 horse I bought from a siezed pressure washer.
Two strokes, although they can really whip that crank around, also suffer from needing the yearly diaphragm replacement, as well as CONSTANT adjustments. New 2-strokes are a lot better, with the primer bulb system, but they are so politically correct with the carb, they aren't adjustable. So, when they inevitably need adjustment, you are screwed.
IMHO
IMHO
