Ventrac
The 30-degree incline is amazing. But the mower and small tractor are connected like a train. That I understand. I will need to check if it is available in Korea. We also check the price![]()
You can see our South Korean Distributor here:
Ventrac - Worldwide Sites
As far as mowing safely on slopes, a few factors play into safety no matter what mower is being operated.
- Operator Experience - Most people do not understand what a 30-degree slope (58% grade) is until they are on one. This can be unnerving to an unexperienced operator.
- Turf Conditions - Loose turf where the sod is not rooted well will lead to loss of traction and tearing of turf.
- Weather - Similar to turf conditions, but wet or soft grass, as well as really dry grass due to current weather conditions can also be unsafe.
With Duals, our engines are rated for continuous operation on 30-degree slopes. Sideways or up and down. Many of the photos are up and down because its hard to really show how steep a slope is sideways and even up and down photos do not do 30-degrees justice, if you get a great sideways shot let me know! :biggrin:
Another note about the reason the Ventrac is safe on slopes is the Weight Transfer System.
Ventrac - Advantages: Weight Transfer
It brings a lot of the attachment weight onto the front axle giving more traction.
I hope that helps, keep up the discussion!
Remember: Safety is PARAMOUNT! No matter what the manufacturer or your friend says, only do what you feel comfortable. If that is 20-degrees, than it is 20-degrees.
