Hello all, I'm new here with a new to me Turf Tiger (STT61) that I can't seem to keep running. It's got a Kohler engine. It seems like I can only keep it running if I put a hot jumper wire from the battery right to the fuel shutoff solenoid on the carb. If I just use the harness wire the engine will only run for a second and then shut off.
Another thing I noticed is that it sometimes doesn't seem to be charging the battery. Behind the control panel I notice there is a yellow wire with a female flat connector that doesn't seem to go anywhere.
Then even if I keep it running with the jumper wire, as soon as I pull in the steering control levers the engine will die even with me sitting on the seat.
I'm new to all this zero turn stuff so bear with me. Thanks.
