J johnmac Forum Newbie Joined Apr 25, 2016 Messages 1 Apr 25, 2016 #1 troy bilt pony riding mower not getting fire to plug
John R Well-Known Member Joined Mar 9, 2016 Messages 240 Apr 26, 2016 #2 Going to need more info than that. :confused2:
R Rivets Lawn Royalty Community Leader Joined Mar 11, 2012 Messages 16,276 Apr 26, 2016 #3 If you would like help, please read this thread and post back with the info needed. HOW DO YOU CHANGE A MUFFLER BELT??
M Mike_Goad Active Member Joined Mar 11, 2016 Messages 67 Apr 28, 2016 #4 johnmac said: troy bilt pony riding mower not getting fire to plug Click to expand... MTD uses a yellow wire to ground out the ignition. find this wire going to the engine and disconnect it. if it starts, the problem is the rider. if it still does not start, problem is with the engine. probably the coil.
