troy bilt
If you would like help, please read this thread and post back with the info needed.
HOW DO YOU CHANGE A MUFFLER BELT??
troy bilt pony riding mower not getting fire to plug
MTD uses a yellow wire to ground out the ignition. find this wire going to the engine and disconnect it. if it starts, the problem is the rider. if it still does not start, problem is with the engine. probably the coil.
