After studying the diagram and doing some testing the only thing it can be I think is the starter solenoid which the blade clutch wiring hooks to or the brake actuator.  I'm sending back this blade clutch so I'm thinking about just buying the solenoid and trying that and if that isn't it trying the brake actuator.  I tried running some tests with the multimeter and couldn't come up with a conclusive answer.
