Toro Self Propell: plastic pieces broke to start the engine, where can i buy them?
  • / Toro Self Propell: plastic pieces broke to start the engine, where can i buy them?
Hey all,
This morning i go out to mow and the pull cord is super loose. It's not grabbing anything... 1/2 the time it wouldnt even retract.
So I pulled the case off the top and the spindle for the cord out and noticed this plastic piece is broke... i also noticed the other piece may be broke, i can't tell if it's suppose to look like that or not.
Thoughts?
And what are these pieces called so I can find them online to order?
Thanks all for the help!
slammed
Hey all,
Thoughts?
We need model numbers people.
Toro Recycler
Manu: 2003
Model: 20016
slammed
Hey all,
Thoughts?
It is the rewind starterParts and Diagrams for Toro Consumer 20016, 22" Recycler Lawnmower, 2003 (SN 230000001-230999999)
HERE IS A PLACE TO GET THE MANUAL http://homeownersolutions.toro.com/portal/server.pt?space=CommunityPage&cached=true&parentname=CommunityPage&parentid=1&in_hi_userid=30166&control=SetCommunity&CommunityID=225&PageID=30031#manualsResultPage
Hope this helps.
Take the rewind to your local repair shop along with your model numbers. Replacing the entire rewind will be faster and cheaper than trying to repair. Ask if he has any used ones laying around. Could be cheaper yet. Don't. Waste your time doing other things.
Great, thanks guys!
