mechanic mark
- Jul 15, 2013
- Threads
- 175
- 7,436
Don't assume anything or get down, read my post above & watch video.Crap. That does sound exactly like what its doing.
Read above by clicking on website. Are you sure you were on correct stroke when adjusting valves? You may have been 180 degrees off. With spark plug out, engine cold of course, insert dowel, pencil, screwdriver, etc. making sure piston is at TDC, top of stroke, then go 1/4" past, both rocker arms should be loose & even with valves closed. You are now ready to adjust both intake & exhaust valves to specs.
