thesilentone
Setting the deck higher or lower at the front or back reduces the cutting arc at the lowest point.
Thanks, but my life is somewhat peaceful. I'm afraid with everything I hear from my wife and her comments about her facebook account, well, don't think FB is a good fit for me. But thanks!You might get the answer from the Facebook Gravely Owners page.
www.facebook.com
You get a finner cut when heelingIt seems like I read somewhere, possibly on this forum, that the best cut resulted from a heeled deck. So several years back I lowered the rear 1/4 from the front. BTW, Gravely HD ZT 60 with I believe a 25.5hp Kohler. I mow often because I'm retired & I like mowing so the grass doesn't get too high between mowings. Have I got a screw loose? I think the cut looks great. Too ****?
Facebook.... now there's a trusted source for factual information.You might get the answer from the Facebook Gravely Owners page.
To discount something just because it’s on Facebook doesn’t mean it’s not factual. There are lots of landscapers on that page who have plenty of experience setting up their decks. There are also several Gravely dealers on there too.Facebook.... now there's a trusted source for factual information.![]()
We're probably talkin' 4 1/4" in the front & 4' in the rear. Scale wheels pretty much hardly turn.....You get a finner cut when heeling
However it only works when you have short grass & are removing 1" or less .
The other problem is scalping and getting the deck stuck on things that protrude out of the grass
Try setting yours up like mine. Put your selector pin in the 4” hole. Outside blades facing front to back. Set your front facing blade tips at 4” and rear facing blade tips at 4 1/8”.We're probably talkin' 4 1/4" in the front & 4' in the rear. Scale wheels pretty much hardly turn.....
I may try that next spring when I'm crawling around on the floor taking off the mulching kit. Funny, each year that keeps getting just a little harder...Try setting yours up like mine. Put your selector pin in the 4” hole. Outside blades facing front to back. Set your front facing blade tips at 4” and rear facing blade tips at 4 1/8”.
I only go on Facebook Marketplace to look at mowers and ATVs for sale and to sell.I may try that next spring when I'm crawling around on the floor taking off the mulching kit. Funny, each year that keeps getting just a little harder...
As it was once explained to me, if the rear of the blade is lower than the front, it clips the grass again and leaves brown tips. I keep mine 1/8" or so above level at the rear. Scalp wheels should ONLY turn when you are going over a rise in the terrain. Keep 'em up!So is no-one heeling their machine?
