LawnWizard
- Nov 17, 2021
- Threads
- 15
- 100
Just a couple of thoughts. 1) as stated above, mow at full throttle. 2) don't cut while turning, do three point turns. 3) check deck for debris or dents that cause loss of vacuum (lift). 4) spindle bearings going out can cause strips. 5) double check your blade heights compared to each other. If the center spindle is slightly higher (bearings) you can get strips. Don't forget to test spindles with the belt off so they can spin freely. ANY grinding or wiggle is a problem. If you do decide to try longer blades you have to be aware of contact with indentations on deck as well as each other. Hope this helps some!
