Switching to longer blades?
They do a FAIR job on dry grass and leaves. However, high lift or OEM blades do a much better job. Remember, mower companies designed their blades to work best with their decks.
Not my experience. The Gators do a better job on both my X758's 60" deck and my Rogue's. I may well be an outlier though, because on my 7 acres there is a huge mix of different types of foliage, including bluegrass, quack/crabgrass, dandelions, creeping charlie, etc.
some before and after results with Oregon G6 mulching blades set at 3" with the grass currently at about10" and damp grass today . . . .
the leaves and bark are from a couple Sycamore trees, huge leaves and tough bark - - -
20250905_140103.jpg20250905_140307.jpg20250905_141408.jpg20250905_141626.jpg20250905_141843.jpg
my 1.5 cents good day Sir what does the manufacturer tell you (tech rep/engineering)
Good luck
All I can say it that BB has already gave me the wrong PN twice this year. First it was a brake cable and just last week the wrong spindle pulley.
Sounds like the blade is running to slow. Might want to check the belt is installed properly. Are all the pulleys the same size?
Hmmmmm, well imagine that . . . . .
Cons & Common Complaints
  • Cut Quality:
    Some reviews indicate that the mower may leave "stragglers" or doesn't cut evenly in very tall or thick grass, potentially requiring a second pass
