I have a fs45 trimmer that i can not figure out what the problem is thought someone could help.I put a carb on it thought that was what it was but still doing the same.I can full choke it and it will idle but when i go to give it throttle it just dies.I can go to half choke and it will go full power than like it runs out of gas.It has a zama carb on it now which is just got one air screw i back it out 1 1/2 turns still didnt help than i changed the intake off thinking it might have a pin hole in it that didnt help either.Could it be a gas tank?Do these models have a filter in the tank or not i cant see one in there?Its like its sucking air from some were but i just cant seem to figure this one out.Im also thinking it might be the head gasket could it be bad?Im not no mechanic but i do know a little about how to work on things i just need someone to tell me what to check for or what to look for.
Thanks For Any Info!
John
John
