Stihl FS45 string trimmer bump knob - cannot remove
Fish
I'll take some better pics here in a minute....
Fish
Fish
This is the mating side view of the cutting head, it has the nut shaped hole to fit on the shaft end.DSCN6216.jpg
Fish
Now, they put this hole here so you might put a pin or nail in to hold the head while you try to loosen the nut.
Fish
And inside the plastic nut is just a regular Stihl bar nut.
dukerocks
Thanks for the EXCELLEXT pics. I used a ice pick through that hole but it would not engage into any hole in the backside of the cutting head - I spun the cutting head slowly while pushing on the icepick. Even if I prevent the cutting head from turning this will not keep the flex cable from turning while I try to turn the nut. I have got to prevent the flex cable from turning while trying to twist off the nut. Thanks
Fish
It sounds like the black plastic cutting head has rounded out, the hex headed hole should lock on the end of the shaft and it should turn only when the shaft turns.
dukerocks
It did not round out - I do have the bare exposed nut. It does not have any plastic around it - the bump knob has been completely cut offf. I need to keep the flex drive cable from turning!!!! Bob
dukerocks
I am attaching pics of what I am working on, just to show you where I am at with this project. As I say, I completely have the bump knob cut away showing the bare nut.
Fish
If you literally clamped the whole black cutting head in a big vise so it couldn't move at all, and turned the nut to the left, what would happen?
Would the drive cable still turn?
