Depend how you are using it.
If you are using it with a blunt blade , labouring the engine with a wide open throttle while applying your whole body weight to try & make it cut then yes 3 gallons will be more than enough to clog the screen.
I can always tell when hubby has sent wifey down to me with his chain saw.
The teeth will be rounded off , the paint on the bar will be burned off and there will be a deep gouge in the blade adjacent to the spikes where he has been forcing a blunt blade to do " just one more cut".
OTOH a woman's saw will require nothing more than 2 strokes of a blunt file to return a chain to razor sharp and the bar will look like it was bought yesterday.:laughing:
