Yes, I plan on doing that before ordering anything. Thanks.Before purchasing a new starter I would remove the starter and do a little troubleshooting. I suspect the clutch is just stuck on the shaft and needs a little cleaning and light coat of lube. You have to remove the starter either way so troubleshooting before purchasing may save you $$$$.
