I've been working on a snapper scrambler 33" zero turn. We mowed with it today for over an hour, then the blade disengaged, and won't engage. I am told the switch has been replaced a couple times in the last year. I'm headed there tomorrow to pull and test the switch, and test the clutch. I read in a thread here that you can turn on the ignition and engage the blade switch and should get 12 V on the connector to the clutch. Will it do that without running? I was thinking that some safety circuit would block it...
If I put 12V direct to the clutch, can you feel it engage? I would think you'd be able to tell by turning the blades...
Model SZT183368bve
Thanks.
Model SZT183368bve
Thanks.
