Mad Mackie
- Jul 11, 2011
- 50
- 1,851
Before there were any HF stores around here, a friend bought a 12 ton A frame model mail-order and brought it to me to assemble for him. When I checked the punched hole alignment in the pieces I was shocked to see how misaligned they were, but I assembled it for him. We tried some pressing on it and as the pressure increased, the entire frame twisted and leaned forward slightly.
I disassembled the press, measured the amount of misalignment of the bolt holes, put the pieces on my milling machine, realigned using an endmill and made the holes slightly larger to accept the next size of SAE hardware. This press worked fine until the 12 ton rated bottle jack started to leak. He was able to find an old USA made 12 ton bottle jack to use on the press. Not long ago he stopped by with a pressing project for me and he admitted that the USA 12 ton bottle jack was too strong for his 12 ton press and trying to press this job, the cross support got bent. I did his pressing job on my press very easily and I offered to cut and weld up a new cross support for him which he didn't want me to do as he had lost confidence in this press. He scrapped the press and now comes here to use my press plus the fact that I have a great assortment of tooling and I'm OK with this.
Even the highest quality presses can get messed up if not correctly aligned with the pieces before pressure is applied, I've seen it happen too many times and I most always make my feelings known. I'm the one with machining, milling, welding and fabricating experience and I usually ended up repairing the equipment most time bringing pieces home to work on. Somewhere I was tagged with the name "Mad Mackie" by some of my co-workers, they may have had good reason, especially if I found out who screwed up the shop equipment!!!! LOL
Mad Mackie in CT :laughing::biggrin::smile:
