SeniorCitizen
Shift on the go ???? Are they describing a variable speed system?
-----------------------------------------------------------------------------------------------------Shift on the go also called shift on the fly meaning no need to stop to shift gears or have to use a clutch, but to change gears while moving.
Here is a link to a thread on the subject.
Yes it does :thumbsup:-----------------------------------------------------------------------------------------------------
The only thing in that link that made any sense was written by ILENGINE .
Historically a typical variable speed mower system had a shift lever for forward and reverse and that was its total function . A second lever , that typically had 7 positions , was to change travel speeds and this speed change lever was to be moved to different positions without disengaging the clutch or even touching the foot clutch in any way .
Does the mower in the original post have this set up? That's my question and I'm stickin to it . :laughing:
Thank You .Yes it does :thumbsup:
