self propelled mower change over to a non self propelled frame
moedawg55
  • / self propelled mower change over to a non self propelled frame
Is there a way to install a self propelled on to a Non self propelled frame?
The frame is a Murray M2255fc 22"
The self propelled engine is a 5.0hp B&S YBSXS 1901VC
The engine will bolt to the deck no problem. the only thing you need to determine is the crankshaft length and diameter the same. cable length could be a consideration as well.
moedawg55
For the crankshaft there are ways around that, I havnt gone deep into it yet, but going to see if I can pull the pulley out, if so then I will drop it in and work from there, cable length may be a issue but not sure till its install, and there are way around the cable issue
