Scotts 2550 won't crank
Yes! But I can't locate a clutch for this particular model/serial number combination.:mad:
Look at the clutch itself. Clean it off and inspect for numbers look closely. Chances are it's a John Deere part because Deere makes the scotts tractors.
Sent from Lawn Mower Forum for iPhone.
Yes, but the JD website doesn't have a clutch for my serial number range. The 2 or three other ranges have a part.:mad:
give us the exact numbers....and ill talk to my guys and see what i can do for you:smile:
Only number on the clutch is on the triangular plate on the engine side. - 0676
Details
Scotts S2554
Kohler engine
Model: CV725S
Spec: 69539
SN: M02554S029831
If the SN was 30000 or greater John Deere has the clutch.
Thanks :thumbsup:
Dennis
Yeah, I saw that one but was afraid it was one of the weaker ones made for smaller decks. I saw some posts where people only got 50 hours on some clutches.
That is the part number listed for the other serial numbers. JD doesn't list a part number for my range.
See this link
John Deere - Parts Catalog
Duh! Maybe I'm reading the JD site wrong. Maybe it is saying to use this clutch but you need the additional parts listed...
this is the number cross match i keep coming up with...ill get some more info for you tmrrw:thumbsup:
