richard fay
- Oct 14, 2013
- 1
- 1
Had my Scag Tiger Cub for about 9 years. The middle of this summer it would start great cut at full throttle and then it would act like it either was running out of gas or flooding - start backfiring and almost stop. I would open up the speed arms and sit until it would come back to full throttle and then go on for a while and then it would repeat, this goes on for about an hour and then it just seems to clear up/stop happening. I thought I had it down to the right gas tank so I took it off and cleaned it. You would not believe the stuff that came out of it. Appareently when Scag drills the gas tanks for the mounting items they do NOT flush the tank so all sorts of twisted pieces of the tanks black plastic is left in the tank. So I thought I had it fixed. Nope. It is still doing it and now it seems to do so on either gas tank. have not flushed the other yet. I have replaced the gas line filter and the fuel pump thinking they were the problem. Nope still doing it. Have flushed the fuel system with carburetor cleaner, Nope still doing it. To me the weird part is it seems to stop doing it after it has been running for an hour or better. I sure would be grateful if anyone knows what the heck is causing this.
PS: the engine has always backfired when I turn it off. The dealer says that it just the Kawasaki 19 hp engine. Sure would appreciate it if anyone also knows how to stop this.
