Rpm issue
Slcasto
Why does my mower barely run, but rpm’s are normal when leaned all the way back with handle on the ground then back to barely running when all wheels are back on the ground?
new gas
New carburetor
New spark plug
New filter
Scrubcadet10
Moderator
Staff member
Need more info, what engine you have etc.
I have an idea floating around my head...
Lets start with more information since Murray has been manufactured by 4 companies using 4 different engines. So the model number of the mower as well as the model number information from the engine. The engine model number is not the numbers on the recoil starter. Depending on brand of engine could be located on a tag on the side of the engine, engraved into the side of the engine, or over the spark plug, or over the muffler
Slcasto
Briggs and Stratton 500e
140cc
5.00
21”
sgkent
define why does it not run. Are we talking about the engine speed, or the speed across the ground? How high is the grass it is cutting. How much fuel is in the fuel tank?
NEVER tip it like that while running. Oil starvation for one.
You have a fuel system blockage. Dump and flush the tank out. Install new fuel line from tank to carb. Set carb float level.
