l008com
- May 25, 2015
- Threads
- 47
- 268
I was given this mower about 3 years ago. When I got it, it had all sorta of issues with the transmission and deck (see my other thread), but the engine ran great. I mean it was an ad for Honda. ~13 year old engine, deck falling apart, but the engine runs like it's brand new. Engine-wise, it felt like a brand new motor. You'd start it up, it started very easily. It would almost instantly shoot up to it's operating RPM and run nice and smooth at that RPM.
But then that all changed very suddenly. Now it runs well when the choke is on, but of course at an RPM that's too low. But when you turn the choke off, it runs very rough, the RPMs bounce around. I shot a video so you could hear it first hand... then I accidentally deleted it. So stand by, I'll take and post a video about a week from now.
So the first suggestion is always that the carb might be dirty. At first I thought this was unlikely, as I almost always run sea foam in my small engine gas at 1oz per gallon. And I run a very strong ratio of sea foam to gas for maybe 1/4 a tank or so to try to really clean it out, but it made no difference. So dirt didn't seam likely. Then I happened to take the airbox off and there was no filter in there. I assume there is supposed to be an air filter on this thing right?
So is it possible that I just need to put an air filter on this thing, then run more cleaner through it till it start running well again? Or is it just a coincidence and is there likely something else entirely going on? It's been fairly well this year, but last year it got to the point where it around sputter and surge so bad with the choke OFF, that you had to keep the choke ON to use it. And with the choke on, it would run almost normally. It was enough to make me wonder if the lever/cable for the choke setting had gotten messed up some how. But it looks fine so I don't know.
Some times next week, I'll take a video and add it so you can actually hear what I'm talking about.
