Rick'sToro8-32
- Apr 12, 2015
- 33
Thanks very much for all of the posts! :smile:
If I am hearing things correctly it seems as though the consensus is that my mower is konking out after about 40 minutes of run time because of a timing issue.
It occurrs to me that this mower has never had a valve job. It think poorly seated valves can mess up the timing. I wonder if this could be the 'cause' of the problem.
Also, in the back of my mind, I think I remember something about a vapor lock in the gas line that creates a situation like mine from a mower when I used to work at a local cemetery. It seems like we had a mower that would run until it heated up and then konk out and then run again when it cooled down. I think I remember the mechanic there saying it was a vapor lock or something like. Does anyone know anything about this?
That is the 'symptom' of my mower: simply put, it runs great until it heats up then it konks out--and when it cools down it runs great again until it heats up and konks out again.
