fifthstring27030
- Oct 31, 2010
- 36
Hi
Sounds to me like op-present switch has gone bad or wires going to it have been cut somewhere. Because you cannot release brake or turn on pto unless you are on seat. Look at terminals on your seat switch to see if it has NC stamped on it. (which means normally closed) if it has no markings then it is normally open which means you close circuit when depressed or you can by pass by connecting the two wires together, NC means the opposite and you have to separate wires. This is a way of testing without a meter.
