Replace needle and seat??
Rls8836
Sorry don’t where to post this so I’m asking here. How do you remove the seat in a carburetor to replace with a new needle and seat on my carburetor. This is a 5.5 horsepower motor on my granddaughters goKart. It’s not a Briggs and Stratton but resembles one. Someone told me it might be a predator engine. I’ve never removed the seat in a carburetor and want to know the way to do it. Thankyou in advance
Scrubcadet10
Moderator
Staff member
If it's a predator, it may not have a removable seat, or it may have a brass seat. some engines use a all metal needle and rubber seat, some use a metal needle with a rubber (viton) tip with a brass seat.
We'll need more information to give you any exact procedures or proper repair parts
Rls8836
Ok tomorrow I’ll go look at the engine, what info you need
Scrubcadet10
Moderator
Staff member
If you can find it, a model number. IF it's a briggs and stratton, it will be stamped into the valve cover, if it's a predator or "Honda clone" motor, there should be some numbers stamped into the back of the block.
Scrubcadet10
Moderator
Staff member
Pictures could be helpful too.
Bertrrr
Remove the carb, turn upside down and blow into the fuel port , if you can't blow through it the needle and seat are ok, When you turn it right side up you should be able to blow through it , this will eliminate the needle / seat or tell if they're bad
Just blowing in without using a pressure gauge is just about as useful as tits on a boar hog. I use a tester and do a 30 min leak down to verify that the float needle valve and seat are sealing.
Bertrrr
I've done it lots of times it's a good initial test - never went any further with pressure gauges etc. but sure it's a more accurate test.
Personally I don't like the taste of gasoline. Maybe it is just my taste. But pressure gauge you if the seal is holding within the design limits but I never to blow enough to hit 7-10 psi for fuel pump setup nor 3-5 psi for gravity setups.
Bertrrr
Yeah , I use a clean hose to blow through to keep gas outa my mouth, you'll know right away if it's a bad seat. Seems cheaper these days to change the whole carb rather than a repair kit.
