Hallowhead
Howdy
I had a br 600 that the choke broke off so I ordered a new carb and replaced. When I push the primer no gas goes thru carb and back down purge line. I've tried old carb now too and nothing happens.
When I push bulb without the carb gas comes through adding the carb back the bulb doesn't press and no gas goes through. Did I somehow break both carbs?
