Welcome to LawnWorld!
I moved your thread to the Small Engine & Mower Repair forum. :smile:
This is a lawn boy engine so i think you should move it back.
how do you remove the engine on a 5021 lawnboy
First, remove blade assy. When taking off blade collar, strike corner of collar with hammer in direction of crank rotation to break taper. Once blade and collar are off, remove muffler. Once muffler is off, remove 3 bolts and nuts that secure engine to muffler plate. Thats it.
Actually the engine mounting bolts are on the outside of the muffler, the only time you need to remove the bottom muffler plate is to take the engine mounting plate off!!:thumbsup:
