Hi all. I am rebuilding my model 7266. It was still running good but I decided to take it apart when I found play in the crankshaft on the bottom of the mower. Figured it was a good time for a rebuild after 36 years. :laughing:
I took the engine completely apart and this is what I found. My piston was scored up on both sides so I am looking for a new piston right now (606607). Cylinder itself should clean up with a good honing. So my question involves the crankshaft play. The crankshaft still looks good with no scoring, so I am not sure if it is upper bearing wear, or maybe the lower bronze sleeve? How much play is acceptable? I already replaced the upper bearing, but have not reassembled everything else yet. Just would like to get an idea about tolerances before I put everything back together.
Thanks in advance!
Thanks in advance!
