Rear wheels bending inwards
Craftsman 917.376742
The wheels bend inwards at the top (oversized rear wheels). Is this normally caused by the arm brackets? I tried to push the bottom of the wheel to straighten it out, but it goes back. Is the arm bracket just weak? I'm debating if the new arm brackets will fix the issue.
It going to more involved than just replacing one part. You need to disassemble the rear assembly looking for worn parts.
Look underneath, and look around the wheels..
You likely will see cracked and broken metal where the hardware is mounted.
