Hello. I had really worn pinion gears so I replaced those and now I noticed the rear wheels (mostly the left) has a bit of a tilt with the top of the wheel closer to the cutter housing than the bottom. This probably has nothing to do with the pinion gear (could have been that way before), but I am wondering if anybody knows what is worn or how to correct this?
