Chattymonk
- Sep 25, 2019
- 1
- 6
I'm new to the forum and will try my best to follow the guidelines and state my question clearly.
Husqvarna yth2454
I was given a mower by neighbor and he said all it needed was a new battery. The mower ran fine with the old battery but I decided to buy one to keep on standby.
I mowed all day with no problems and the next morning I went out to start the mower and forgot to push the brake in so my first thought was "welp time to change that battery".
I put in the new battery and everything seemed fine except for when I would try to engage the blades. At first they would go but then they started acting like they weren't getting enough power and the hour gauge would turn off too so I thought maybe the new battery was the problem. I put the old battery back in and the mower was completely dead. The hour guage won't event turn on. Checked the new battery and put it back in. Still dead.
I've done multitude of different checks over the last week but cant get anything going.
I used a multimeter to check the battery and the ignition switch and they seem good. Replaced the fuse, cleaned all corrosion from positive and negative wires from battery to solenoid.
The solenoid was getting 12.5V on both sides so I hesitantly tried the screwdriver arc trick and got nothing. I also want sure if I rewired the solenoid wrong so I've tried the black and white wires on both sides.
I still need to check the connection to the starter motor and a few other things but it has been difficult because I'm still learning how to check it using the multimeter and only have internet while I'm at work.
There is white male quick disconnect that come out beside the small live/ground wires that go to the solenoid and I cant for the life of me figure out where it goes. I've looked at the diagrams for my mower but cant figure it out. I'll try to post some pictures.
I'm pretty baffled by it. Even if the solenoid or starter are bad I would expect the hour gauge to get power.
Sorry for the long post. I just wanted to add as many details as possible.
Anyone know what this wire does? It had a plastic casing over it that broke.
Husqvarna yth2454
