MowerMark
- Mar 1, 2014
- 57
- 286
This mower is about four years old. A year ago I removed the blades and asked a mower shop to sharpen the blades ($15). This time I decided to sharpen these two blades myself when there appeared "mohawks" (see below). Found this hand held carbide device for $8 on line. Three rubs to each edge and twenty seconds later the blades sharpened nicely. Sweet! After reinstalling them, not sure I put them back properly but at least the sharpened edges contact the grass first. The grass now has a clean cut edge on examination of the cut blades.
PROBLEMS:
1. There's a slight clicking sound as they rotate, but it's getting less
2. The grass still "mohawks", that is despite mowing the in the usual pattern done in past years, often a very narrow band of taller grass remains. It was this "mohawking" which prompted my sharpening these blades. Sharpening maybe reduced it a little. What causes this ?
I looked on-line and at the manual, and all it states is to put them back the way they were installed. Duh. I didn't pay attention. Where may one find a picture of proper blade placement ?
* As a separate question, how best to clean the underside from all the grass accumulation ? Wooden stick ? Spatula ? Is it okay to spray water in the area when the mower is on its side ?
* And yet another question. I enjoy using AMSoil Synthetic products in my car (260,000 miles). May I use AMSoil 10-30 Synthetic oil in this mower ?
* I've heard debates on blade sharpness. How important is it for these blades to be sharp, and how sharp should they be ? The lawn mower professional who sharpened the blades a year ago said that the blade need not be sharp to cut grass.
Thank you,
Mark
PROBLEMS:
Thank you,
Mark
