Hi, had the PP015G30 for about 8 years now. Last your it became difficult to start. Had to rapidly repeatedly turn the ignition switch to start before it would fire up. After the first start it would start fine on first attempt. Starter would spin rapidly when it engaged. No sluggish crank, strong action. This season I bought a new ignition switch and installed it after disassembling the old one and cleaning the contacts did not improve it. Now the new switch and the old switch will not start it even after a couple minutes of trying to get the thing to crank. No solenoid click or starter activity. New battery at 13 volts. Old switch and new switch both show continuity on the same pins when key put into on and when the key turned to start. Under seat kill switch also tested good. Brake pedal switch is being depressed by the lever.
I did a search but didn't find any thread about the PP105G30.
