Briggs & Stratton, "Diamond Power", 6 HP, on 21" cut, self propelled walking mower.
Model#12H800, Type # 1538-21, Code#96022756
Does not appear to be getting spark at the plug. I pulled off the flywheel expecting to see stuck points. There were no points. Disconnected the Stop Switch as I thought it might be grounding out. Do the Armature-Magnetos give much trouble on these?
Would like to find repair manual info to test the Armature-Magneto before spending $50+ on a 20 year old machine.
Also, would like to know the correct Spark Plug for this engine.
Any help appreciated.
