New mutli tool (I need suggestions)
Could anyone of you recommend a well priced hand help blower that would be strong enough for the fall? it is so quicker than racking for hours:thumbdown:
I once worked with a Shindawa handheld blower for two days straight and it was awsome! Gobs of power also! Alltho, I forgot the model:frown:
BG 86 Specifications​
27.2 cc (1.66 cu. in.)
4.4 kg (9.7 Ibs.)
85 m/sec (190 mph)
69 m/sec (154 mph)
[TD="width: 50%"]DISPLACEMENT[/TD]
[TD="width: 50%, bgcolor: #dcdcdc"]ENGINE POWER[/TD]
[TD="bgcolor: #dcdcdc"]0.8 kW (1.10 bhp)[/TD]
[TD="width: 50%"]WEIGHT[/TD]
[TD="width: 50%, bgcolor: #dcdcdc"]FUEL CAPACITY[/TD]
[TD="bgcolor: #dcdcdc"]440 cc (14.9 oz.)[/TD]
[TD="width: 50%"]AIR VELOCITY
Flat Nozzle
Round Nozzle[/TD]
[TD="width: 50%, bgcolor: #dcdcdc"] AIR VOLUME
Flat Nozzle
Round Nozzle[/TD]
610 m[SUP]3[/SUP]/h (359 cfm)
780 m[SUP]3[/SUP]/h (459 cfm)[/TD]
4.4 kg (9.7 Ibs.)
85 m/sec (190 mph)
69 m/sec (154 mph)
Flat Nozzle
Round Nozzle[/TD]
Flat Nozzle
Round Nozzle[/TD]
The Stihl has higher numbers than the Echo, but I still think you would be happy with either. :thumbsup:
PB-255LN Specifications
15697d1373920724-new-mutli-tool-i-need-suggestions-pb-255ln-png
15697-new-mutli-tool-i-need-suggestions-pb-255ln-png
Your blower is 157 mph, that's almost as much as the PB 150t @ 163 not to bad for a hand held, do you or did you get a flat and round tube with that one.
It came with only the flared tube, but you could probably pick which one you wanted at purchase.
The Stihl BG86 I think comes with both and yours and it are the basically the same. I've been thinking about one but can't really justify spending the money at the present or should I say my wife says I can't justify spending the money :rolleyes:
You should get it! :dance1:
Thanks for the other suggestion. Alltho, the STIHL BG86 seems a little more expensive than the ECHO. I am uncertain wich I will get.
