New Echo Equipment
Interesting.. I am going to explore that a little I have 3 dead 225 carbs now. I'll try cleaning that screw and see if that works.
How do you adjust the jets? Thought they weren't adjustable. I've been through the machine 1000 times never seen an adjustment screw
The high speed needle jet screw is hidden behind a plug that must be removed to gain access. The plug is located just below the primer bulb. You turn the needle jet screw CCW to make the fuel mixture richer.
