Need help for a possible lost cause
cjdave
I got this riding mower in hopes of repairing it for myself but I am finding out that it may be a lost cause! The tag with the model and serial numbers is partially missing and I only have a partial model number. Model # 917.2588??. Best I can tell I am missing the last 2 digits. All I have to go on is the motor- Kohler Command 18.5 model # CV18S. The motor looks good but the mower is missing the deck and possible other parts as I haven't tried to tear into it yet. I am attaching pics. If anyone can help with a way to get the model # or any ideas what would cross over for parts I would greatly appreciate it!
Thanks
David
Mini Motors
I suggest going online to SearsPartsDirect.com and key in the part number you have and starting at "01" add the last two digits until your mower shows up. It'll take a while, but at the most, you'll only have to do it 99 times!
Suggest the same, except just type in the number you have and a list will appear.
cjdave
Thainks I will give it a try thanks again David
earthworm
I'd try to find a good mower junque-yarde...One identical to yours may be there...and with reason, usually.
RandallCooper
Im new here but I believe that one is about 17 years old I could be wrong but Google might help you with the just put in what you have. I see allot of craftmans used that engine.
This is what I got from sears http://www.searspartsdirect.com/par...&pathTaken=modelSearch&prst=0&shdMod=917.2588
Your guess it good as mine on which one it would be. Good luck
EDIT:
After doing more I found this
http://forums2.gardenweb.com/forums/load/tractor/msg0123132130947.html
which led me to
https://www.google.com/search?q=917...ct=mode&cd=2&ved=0CHYQ_AUoAQ&biw=1440&bih=781
So your model number might be
917.258872
cjdave
Thank you very much it is just like mine. Now I have to find a deck for mine. Thanks David
