Hello,
I am new here glad I found this I am working on a YTH 22V46 (96045004500) - Husqvarna Yard Tractor (2013-08) I replaced the carb new spark, replaced the head were the pistions are. Fired it up and it was smoking oil out the exhaust and back firing. I cant locate the specs to adjust the valves in MM the exhaust valve is opening but only a little. I noticed that on the front cover were it says ovh it seemed like it had too much compression. I am not sure how to adjust the carb also. Any input would be great thanks in advanced. It has a briggs and straton on it.
Lost
Lost
