jmurray01
, , 1,000 Post Club
Ah I see. It sounds like the tensioner isn't tightening the belt enough, as you said.Ya, I had thought that at first too....It is the right belt, I had to go to Tractor Supply and get the right one....Also it is on the right way just seems like the pulley is not putting enough tension on the belt....When I pull the pulley back it has good strength with the spring but maybe it is not applying enough pressure on the belt ???
If it isn't too expensive, I'd replace the tensioner.
