robert1950us
 - Apr 18, 2023
- Threads
 - 5
 - 13
my Troy-Bilt model 13AQA1BQ011 the pto switch works intimately so I have decided to change it but I cannot find the removal process anywhere on line. Any one has any suggestions?
			I checked as you suggested and with the new switch the mower is still having the same issue, could it be the main drive belt slipping due to wear. just for your info my Mower Model # 13AQA1BQ011 Super Bronco 50XP. Thank you for your time and assistance.Check electrical harness plug at backside of PTO switch for being loose. Pick up a spray can of CRC Electrical cleaner & a tube of Silicone Dielectric Grease to seal out moisture from connection.
I'd keep it....switch works intimately so I have decided to change it ... Any one has any suggestions?
