kohler courage 27 hp will not restart
ACF
have a cub cadet gt1554 model 14ak13bk709 with the following engine kohler courage 27 hp model sv740-0010. first problem was there was no spark so replaced spark advance module (coil) ran for a few days then no spark. so replaced coils mower will start and run but when you turn it off it will not start again, let it set for a day it will start. coil orginal part number 24 584 63-s / 24 584 89-s these were suspended to 25 797 03-s. looking for any help to get this starting every time you turn the key
mechanic mark
See troubleshooting section after locating your engine Service Manual above.
I would first check ground connections from engine to frame/chassis for being tight & secure by hand, try to move. Check all electrical connections, including Ignition Switch, PTO Switch, etc. behind dash & everywhere. Have you ever removed Blower Housing, cover over engine, & cleaned engine cooling fins. Grease, dirt, & debris will cause engine to overheat & create all kind of problems, including engine failure. Engines need to be clean so they can run cooler at all times without hesitation.
Cub Cadet Professional Shop Manuals above, save on your device, your GT 1554 is listed, let us know how it goes, thanks Mark
