Engine runs good until it kills battery completely. Changed voltage regulator. Checked stator. Ohms good. Checked votage output coming out of stator (engine running) 27volts. Voltage out of the regulator is 14v. Voltage at battery(engine stopped) 12v....engine running 14v....but not charging battery??? Changed battey....Same issue. If i disconnect the battery the engine dies. I can't figure what to do next....appreciate any suggestions...Thanks in advance.
