BELT DRIVE AND IDLERS
Cart key PART NO. PART NAME QTY SERIAL NO. REMARKS
1 03M7187 Bolt 1 M8 X 35
2 14M7298 Flange Nut 5 M8
3 03M7216 Bolt 1 M8 X 50
4 M147132 Guide 1 BELT (SEE SIB. 02-11-25-06)
5 M131045 Bushing 1
6 M125774 Arm 1
7 19M7177 Cap Screw 2 M6 X 35
8 M43940 Snap Ring 1
9 M127620 Spacer 2
10 M127358 Pulley 1
11 F2863R Snap Ring 1
12 M127359 Fan 1
13 14M7397 Lock Nut 2 M6
14 M126636 Extension Spring 1
15 37M7089 Screw 2 M6 X 12 (IF THREADS ARE STRI PPED USE 19M7862 AND 14M7397)
16 M142313 Screw 3 M8 X 1.25, NLA; ORDER M167872
M167872 Screw 3
17 M151397 Guide Bar 1 BELT (FOR 38" (97 CM) AND 42" (1 , 07 M) DECKS) (SUB FOR M126531)
AM126546 Guide Bar 1 BELT (FOR 46" (1, 17 M) DECK)
18 M125786 Guide 1
19 M129045 Guide 1
20A ...... Bracket 1 - 045000 (SUB M141952) (ALSO ORDER AM130736)
20B M141952 Bracket 1 045001 -
20C AM130736 Converter Kit 1 NLA
21 M126633 Bushing 1
22 19H3837 Cap Screw 1 7/16" X 5"
23 M123830 Lock Washer 1
24 AM121968 Idler 1 (SUB FOR AM107335)
25 03M7224 Bolt 1 M8 X 65
26 M126009 V-Belt 1
27 AM131567 Pulley 1 (SUB FOR GY00034)
28 19M7803 Screw 1 M8 X 70
29 24M7298 Washer 1 8.400 X 25 X 2 mm
30 M125775 Guide 1
31 AM121970 Pulley 1 FLAT, (SUB FOR AM104666)
32 AM121967 Idler 1 V-GROOVE, (SUB FOR AM107334)
33 M70570 Spacer 1
