John Deere LT 160
Harold54
Engine dies when releasing brake pedal to engage transmission. Have already replaced all switches.
DaveTN
Does it do this with the blades spinning as well as not? If the engine dies, to me it would not be a "switch" problem, but not getting enough fuel causing the engine to stall out. Unless the pedal switch is somehow causing the engine to die, but you said you replaced them. Could be a wire shorted out someplace near that switch. Safety switches are great till they mess up.
I would check the seat safety switch first. From your description it's just like no one is in the seat.
